What is your preferred quick extrusion profile size?
Discussion in 'Other Builds' started by SamuelT-E, Aug 17, 2016.
Tags:
If you have to choose between 40 mm x 40 mm profiles and 45mm x 45mm profiles for general applicatio
  1. 40mm
    1 vote(s)
    100.0%
  2. 45mm
    0 vote(s)
    0.0%
  1. SamuelT-E
    SamuelT-E New
    Hi guys,
    Probably some of you use quick extrusion profiles like 8020 profiles for tooling design.
    I have 2 questions for you.
    What size do you think is the most useful or what size you usually use for a specific application?
    If you have to choose between 40 mm x 40 mm profiles and 45mm x 45mm profiles for general applications
    witch one will you choose?
    Since 40mm and 45mm have similar mechanical properties, if you use one or other may be you have a reason why prefer one.
    Tank’s for your comments!
    What exactly does 45mm mesh with? Sure that's 3 times a 15mm extrusion but we don't use 15mm extrusion here. And I could understand 50x50 as that's almost 2" but where does 45mm come from and what does it fit?
  3. SamuelT-E
    SamuelT-E New
    Thanks Rick you for your reply, I'm not searching to mesh it with anything I just want to know what is the best size for general application like table and cassette, industrial cart, part dispensers, conveyers etc
    You guys witch size do you prefer?
