what is the difference between the tb6600 ht, gh, bh
Discussion in 'General Electronics' started by R.S., Feb 26, 2018.
  1. R.S.
    R.S. New
    what is the difference between the tb6600 ht, gh, bh and if there is a difference will it run these ok
    Manufacturer Part Number 23HS45-4204S
    Step Angle 1.8°
    Holding Torque 3.0Nm(425oz.in)
    Rated Current/phase 4.2A
    Phase Resistance 0.9ohms
    Recommended Voltage 24-48V
    Inductance 3.8mH±20%(1KHz)
    Weight 1.8kg
  2. Gooshpoo
    Gooshpoo Well-Known
    All i know is the TB6600 is based off of the Toshiba TB6600HG chip .
    It would drive the motor but I wouldn't cheap out. these drives from china are not quality and you have no room for improvement.
    DQ542MA Stepper Motor Driver
    5056 - 20-50VDC 5.6A Microstepping Driver
    in my opinion these drive are better and should last you . there are a lot of options these are on the cheaper side of things
    GrayUK likes this.
  3. R.S.
    R.S. New
  4. Giarc
    #4 Giarc, Mar 15, 2018
    Kyo likes this.
