What is the depth for the tapped screw holes on the C-beam?
Discussion in 'General Talk' started by Jason Kraft, Jan 15, 2016.
Tags:
  1. Jason Kraft
    The parts store says that 4 of the holes on the C-beam are tapped for easier assembly. Does anyone know how deep the taps go? I would like to know so that I can order the correct screws for the job.
    jkmcc13 likes this.
  2. Steve Fox
    Steve Fox Well-Known
    The holes are threaded all the way through and the plates are 5mm thick.
    There isn't a lot of space between the plate and the extrusion, so the screws can't stick more than 1mm or so past the plate.
  3. Ronald van Arkel
    @ Jason,
    The tapped holes are 10mm (3/8") deep,
    @ Steve,
    Jason was talking about the ends of the C-Beam, not the gantry plates for the C-Beam ;).
    -Ronald
    jkmcc13, GrayUK and Mark Carew like this.
