Water cooled spindle
Discussion in 'CNC Mills/Routers' started by davels, Aug 29, 2017.
  1. davels
    davels New
    Hello,
    I'm new and just receive my ooznest OX cnc without a routers. I want now, buy a spindle. As the cnc will be in a bedroom, I would like to save some decibels as more as possible so I would like to buy a water cooled spindle.
    The cnc is 1.5*1.5m. I would like to mill mdf, hard wood, plexiglass and if possible, aluminium.
    I saw sometimes Huanyang coming for the spindle, is it a good manufacturer? Do you have another manufacturer to suggest?
    And also, what kind of motor, 800W, 1500 or 2200W? I could read some issue with the weight of the spindle, does the 2200w to heavy? I like the possibility to use an ER20 collet.
    I'm in Belgium, if you have some store to advise, just let me know :)
  2. Ryan Lock
    Ryan Lock Veteran
    Hi,
    I believe a 2200w spindle will be to heavy. Has the manufacturer got weight specs for each one?
  3. davels
    davels New
    5.8kg for the 2200W, 4.4kg for the 1500W and 2.6kg for the 800W.
    What's an acceptable weight?
    Edit : I guess the weight issue is about the X axis gantry to bend?
    #3 davels, Aug 29, 2017
  4. Ryan Lock
    Ryan Lock Veteran
    Hi,
    Ok they are quite heavy. I would go no larger than the 800w spindle.
    Yes it is a significant weight.
  5. davels
    davels New
    I can easily find the 1.5 or 2.2KW :/ Not the 0.8KW.
    What could I do to avoid the gantry to bend ?
  6. Kyo
    Kyo Veteran
    Here is a 0.8KW Kit 110V setups are available "Here" and "Here" to if you can not use a 220V unit.
    eddiejr likes this.
  7. davels
    davels New
    Thank you, but as I'm in europe, amazon.com doesn't delivery (or at high delivery cost) in belgium.
  8. Kyo
    Kyo Veteran
    Sorry about that, I completely skimmed over your location in your first post... A quick search on ebay.be shows a few 0.8KW options that might be worth a look..
  9. GrayUK
    Hi davels.
    I noticed you mentioned that this machine is in your Bedroom. You do realise that the CNC is going to be noisy and very dusty as it works? :jawdrop:
    Have you taken this in to account? A serious need for a sound cabinet, and a good vacuum would be highly recommended, especially working with MDF! :(
    Gray
  10. davels
    davels New
    Well, it will not be in my bedroom but in a room who should be a bedroom. But it will be my bedroom next room :sleepy::blackeye:
    This is the reason why I want a water cooled spindle, less noisy. I plan to build an enclosure, but before doing it, I wait to check how noisy it is :)
    Thank you to advise me :thumbsup:
    GrayUK likes this.
  11. davels
    davels New
    Thx all for your feed back! I order a 2.2KW HuanYang inverter with a 0.8KW HuanJiang spindle water cooled. According to the seller, it works well. As he has 99.9% with more than 2600 orders, I believe him.
    Any advise on the bits to use for mdf and acrylic?
  12. SCYBUCK
    SCYBUCK New
    Dave,
    How did the 2.2 KW spindle work? Was it too heavy or not? Have you cut any aluminum yet?
  13. DA_Spec
    DA_Spec New
    You dont need a water cooled spindle air cooled is fine and make sure your gantry is stiff enough to received the weight of your spindle
  14. Giarc
    Actually, he ordered the .8 KW spindle.
  15. davels
    davels New
    Indeed :)
  16. chrystalide
    Hi davels,
    I'm also live in Belgium.
    I suppose you have order a 0.8kw with an er11 ?
    Do you still have the link to buy the spindle ?
    I'm looking to find a seller with a depot in Europe.
    Bertrand
  17. Christopher Harris
    On a C-Beam XL, 0.8kw is plenty, correct? And is water cooled quieter?
  18. sebcbien
    sebcbien New
  19. chrystalide
    Hi,
    Finally i have ordered by this seller.
    The product come from Germany.
    Bertrand
  20. sebcbien
    sebcbien New
    Hi Bertrand,
    Thanks for the link.
    However it seems they do not have 800W air cooled kits anymore.
    Did you end up getting a 1.5kw ?
  21. chrystalide
    Yes, this one
    But don't hesitate to send a mail.
    Bertrand
  22. Hanz
    Hanz New
    Yo tengo un workbee con husillo de 2.2 kw y hasta ahora no me ha dado problema.
  23. SCYBUCK
    SCYBUCK New
    Perhaps there may a factor equal in importance to rated power or weight of the spindle. Consider that it would be nice if it would handle an ER-20 collet. Spin those 1/2" end mills! The chips look sweet being ejected from the cut! I am still working out and documenting speeds and feeds for my 2.2 KW water cooled spindle on Kyo Sphinx. Yes, the water cooled spindles spin whisper quiet at no load.
    #23 SCYBUCK, Nov 28, 2018
  24. Kasham
    Kasham New
    Hi, please my problem is mounting the spindle on the machine! How do I get mounts for the .8kw spindle?
  25. GrayUK
    Hi Kasham and welcome. :thumbsup:
    As you can see, the last entry on this thread was quite some time ago. :(
    You might be better to start a new thread of your own, and may get more response.
    Gray
    Kasham likes this.
  26. Peter Van Der Walt
    Some sellers offer a mount, that will of course not be compatible with V-Slot. You'll have to drill and tap their mounts to suit.
    Or if you have the 65mm diameter version, consider a 3D printed shim to fit our Router Mount (69-72mm fit)
