Wanhao Duplicator i3 Plus - Majpr rebuild.
Discussion in '3D printers' started by John Pollman, Feb 22, 2019.
  1. John Pollman
  2. arcrunner
    arcrunner Well-Known
    Nice! Planning on doing the same with mine. My main issue is the bed shaking/racking at higher speeds because of how the belt is attached so far away from the actual bed, it's sort of a cantilever. New bearing, longer bearing, new rods, igus bearings, nothing seems to change that ripple I get on the y axis, so going to an extruded aluminum build would let the belt path be closer to the bed.
    John Pollman likes this.
  3. John Pollman
    In three of the pictures, you can see the part that I designed and printed for connecting the Y belt to the bed. It doubles as a tension adjuster.
  4. Normand Frechette
    Hello John,
    I'm interested in knowing how your rebuild project to progressing. Do you plan on updating your project anytime soon?
  5. John Pollman
    Hi there,
    I finished the rebuild a couple of years ago and it's working great.
