Wall painter---looks simple ?
Discussion in 'Concepts and Ideas' started by Lozza50, May 27, 2014.
  1. Lozza50
    Lozza50 New
    This machine build is achievable. The X axis is a rodless pneumatic reader, the Z axis is controlled by stepper/servo , vertical axis is simple I think . The print head is available through Epson which prints best guess 3 to 4 cm above media.
    The ink is Acentone vinyl resin , uses Photoshop . Here's were I get lost how to connect printer head driver, photo shop etc.
    I invite active comments . Go to LAC ARTROBO on you tube or LAC. Corporation on internet.
    Lozza from OZ
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    A very interesting and ambitious project Lozza50 :thumbsup:
    As you say, it is definitely achievable but may require quite a bit of research and experimentation to get the print head software and control sorted.
    This should keep everybody's brains active for a while ;)
    Tweakie.
  3. Lozza50
    Lozza50 New
    Also " you tube " vertical wall inkjet printer .
    Loz from Oz
