W|W plasma 1500x1500 (floating head & z-axis)
Discussion in 'Laser Cutters' started by wojak, Feb 5, 2019.
  1. wojak
    wojak New
  2. Mark Carew
    Nice work @wojak from the looks of it this is going to be a great machine :thumbsup:Thank you for sharing
    wojak likes this.
  3. Tracy Ranson
    Tracy Ranson Well-Known
    What are your plans to control the height of the torch? I have built an OX to be used as a plasma cutter as well, I can't afford a THC so I am open to ideas for height control for the torch. Nice build by the way.
  4. wojak
    wojak New
    Thank you :)
    I am using MyPlasm CNC controller.
    It has THC built in, also software is included and creator is very helpful and active, so I think it was good deal.
    Proma-elektronika
    Later I will try it with other controllers, it is described here:
    Plasma THC - LinuxCNC
    Also Stefan Cymbaluk covered a little about it and thanks to him I found it:
    This was my first choice and I don't know any other solutions.
    EDIT:
    Maybe this solution will fit your needs:
    A very entry level Torch Height Control from cheap available parts
  5. mytechno3d
    mytechno3d Veteran
    Hello
    Really good job , i think i will modified my floating head and add your proximity sensor.
    I try to use some THC , but was not really happy with it .
    On small size ( my maximum cutting size is 1300x1300 ) , i prefer to do Z Zero every time the move is higher than 25 cm.
    It is done by my postprocessor in sheetcam . So my cutting height is good on all my cut .
    For my next table , i think i will try plasm cnc controler who seems to work really fine
