Voxel with Acme Lead on X and Y
Discussion in 'Concepts and Ideas' started by psi3000, Feb 8, 2018.
  1. psi3000
    psi3000 New
    I like the Voxel build. But I want to use the Acme Lead screw V-Slot Linear Actuator on the X and Y axis. I personally believe the Lead screw movement to be better then drive belt, in acuracy, price and maintenance free operation. Am I correct in believing this? Is there any reason I would not want to use this Lead Screw over the belt? Also replacing the Y axis with the Lead screw setup is easy as pie on the voxel, simply mount it on the bottom. However, how would you do this on the X axis?
  2. Giarc
    Lead screws have better resolution, but are much slower. That is why the x and y on 3D printers and laser engravers are using belts.
