Vertical Mill
Discussion in 'CNC Mills/Routers' started by dtanney, Nov 22, 2017.
  1. dtanney
    dtanney New
    dtanney published a new build:
  2. Lee Whiteley
    What kind of spindle motor are you using?
  3. dtanney
    dtanney New
  4. Gary Caruso
    what linear bearings are you using.. I see MGN12, from where, how do you like them? Thanks
  5. dtanney
    dtanney New
    The ones I got are in the links below. They are nice but a little loud (not loud enough to be noticeable with stepper motors and the spindle moving) maybe some lithium grease will fix them up. The only thing about them is they require a lot of screws to hold them down but the rigidity of them make it worth it.
    I got these ones
    MGN12H Linear Sliding Guide / Block 250 300 350 400 450 500 550mm CNC 3D Printer | eBay
    along with for extra blocks
    MGN12H Linear Sliding Block Carriage 45x27x10mm for Guide Rail CNC XYZ DIY TE808 | eBay
