Vacuum chuck
Discussion in 'CNC Mills/Routers' started by Greenman, Jan 23, 2014.
  1. Greenman
    Greenman New
    I wanted to post a picture of a vacuum from Joe woodworkers website. It is shop made and it vacuums on the top and bottom. So it is locked to your table. Each one of the four areas in the block has a ball bearing valve. When you put on your piece it depresses the ball and pulls a vacuum. I use vacuum clamping and holding in my guitar making. I have a venturi system I built as a kit that runs off my compresser and a continuous run Gast pump I got on ebay for about $60. Both work great a lot faster that hand clamps or screws to hold things down. main.jpg
    bobt likes this.
  2. Mark Carew
    What a great idea @Greenman , thanks for sharing
  3. bobt
    bobt Well-Known
    @Greenman, Can you post a link to the vacuum clamp and the venturi that you made. Or just post a project for these as there are a lot of us that would like to use this on their tables.
    Bob
  4. Greenman
    Greenman New
  5. Greenman
    Greenman New
    What I built is the V2
  6. Mark Carew
    Thanks for the link, cool site!
  7. bobt
    bobt Well-Known
    Thanks @Greenman - and my wood/metal/cnc shop thanks you more than you know. Just what I need is another project. YES!!! It is on the list now.
    Bob
  8. Greenman
    Greenman New
    Joe Woodworker is good to work with. His prices aren't a rip. I built the V2 and it was pretty easy works good. I am thinking of building a tanks system for my Gast pump so it doesn't have to run constantly. The other thing he has is a foot switch to turn the vacuum off and on. That is worth checking out.
