V Wheels - Other materials, beside Delrin, PC and steel?
Discussion in 'Concepts and Ideas' started by flint, Sep 11, 2018.
  1. flint
    flint New
    Has anyone looked into using other materials to make the v wheels, beside Delrin, PC or steel?
    Delrin wears out too quickly, PC is expensive, and steel wears out the extrusion/rail.
    Would appreciate a suggestion for something close to PC in properties, and to Delrin in cost, for a custom sized wheels project.
  2. Gary Caruso
    Flint, you think PC is expensive wait till you start looking at the fancy high tech engineering plastics, they are crazy. :eek:
  3. Rob Taylor
    Seems like urethane should be a logical option- available in a variety of hardnesses, easy to both precision cast in silicone and machine, tough and wear resistant... You need a vacuum chamber and pressure pot to cast it really well, but they're much closer to being normal maker supplies these days than they used to be.
  4. Scotty Orr
    Scotty Orr Journeyman
  5. Rob Taylor
    I wondered about that too- it was my very first thought, then I second-guessed myself because I assumed there was some reason no one was already doing that. It seems like it would be by far the cheapest and easiest to both individually- and mass-produce? I could see them potentially struggling with shock loads, maybe, but I feel like they'd be perfect for lasers and printers. Maybe they transmit too much vibration? Aluminum is the worst for that.
  6. JustinTime
    JustinTime Journeyman
    I think the aluminum wheels are not used more often is that they make way more noise when running on metal.
    Rob Taylor likes this.
