V-wheel obstacles
Discussion in 'General Talk' started by Rink, May 12, 2021.
  1. Rink
    Rink Well-Known
    This may be a stupid question, maybe I’m missing something simple.
    I’ve been looking at the various linear motion options. V-wheel vs round rail vs shaped linear rail, etc.
    On my Nextwave Piranha, there are round rails with tight-fitting bearing housings that wipe away dust as it moves along the rail. Works good.
    Carving can fling a lot of chips around. With polycarbonate wheels on v-slot, on top of the rail, how likely is it that chips/dust get flung onto the Y-axis aluminum rails and present an obstacle to the wheels? Seems like a small chip could stop the wheels in their tracks, so to speak, and jam up the movement completely.
    Since a lot of people are using this linear motion design with great success, logic tells me it must not be too much of a problem. But it seems like it could be.
    I would appreciate any insight on that.
    Thx, rink.
  2. Giarc
    I have not had an issue with it in the 5 years I have used them. If you use a dust shoe, it will help a lot. I cut a lot of aluminum, plastic, and wood with no problems.
  3. David the swarfer
    I have a handy paintbrush which i use to brush the Vslot clean between or during jobs.
    I suppose one could permanently attach wipers, but I always stand by the machine when it is running so I just keep an eye on all of it. I never turn my back on a running machine (-:
    Corey Corbin likes this.
  4. Kevon Ritter
    Kevon Ritter Veteran
    Having experience with the original Shark and seeing how they haven't improved the design other than looks, I'll say without hesitation that Nextwave machines are garbage. I literally threw mine away. Although it also has its limitations, the v slot system was a major upgrade.
