V-slot, 80/20, makerbeam are these compatible?
Discussion in 'General Talk' started by Rodm, Feb 1, 2017.
  1. Rodm
    Rodm Well-Known
    Hi,
    Had considered the 80/20 5010 beam (50x100mm) beam as a option for stronger x and longer y runs. Are parts from these other sources compatible?
  2. evilc66
    evilc66 Journeyman
    The slot spacing has to be multiples of 20mm for the other parts to be directly compatible. You will lose support for v-wheels with the likes of 80/20, Bosch, Misumi, and others, as they don't have the same slot profile as v-slot.
  3. Rodm
    Rodm Well-Known
    Thanks,
    good to know.
