Using the machine frame as a ground.
Discussion in 'General Electronics' started by Crchisholm, Mar 8, 2018.
Tags:
  1. Crchisholm
    is there a reason I can not or should not use the machine frame as a ground for my end stops as long as i ground the GRBL to the frame?
    you should not, because it creates ground loops.
    for best electrical noise resistance you must use a star ground.
    there is one ground point, and everything is grounded to it.
    this includes the frame, which means the frame cannot be used as a conductor.
    Why star ground????
  3. Crchisholm
    Good information. If I understand correctly, it would be a roll of the dice on whether I had problems related to this or not. Since, I have enough bad rolls without adding more, I will stick to the ground coming back to the Grbl.
    Thank you for educating me a bit more,
