Usage of 'Anti-Backlash Nut Block for 8mm Metric Acme Lead Screw'
Discussion in '3D printers' started by Selvakumaran, Nov 27, 2015.
  1. Selvakumaran
    Hi,
    We are planning to use 8mm ACME Lead screw for the Z-axis in our new 3d printer. When we saw the Open-builds videos with ACME lead screw, mostly they are using only 'Nut block for 8mm ACME'.
    Then what is the use of 'Anti-backlash' nut.
    For Z-axis with ACME lead screw, which one is the best - Nut block or Anti-Backlash nut block?
    Thanks in advance.
    The anti-backlash nut was a recent addition to the shop and many of the videos may predate its existence. For the Z-axis on a printer its use is probably not all that relevant as there are not significant counter or inertial forces on the mechanism.
  3. Selvakumaran
    ok.. Thanks for the reply..
