Ugs movement & endstop
Discussion in 'Control Software' started by Evan Leavitt, Apr 21, 2019.
  1. Evan Leavitt
    I have a two part question using Ugs 0.9 Is it common for endstops to stop any following actions/movements? If I'm jogging my gantry and test and endstops I have to close session and reopen to move again. Second part is there a command/setting to move in any directions freely (in programming I invision i++ type setting). I have a game controller and it moves in increments base on predefined settings the next movement has to wait for the previous command to finish. Thanks in advance.
  2. sharmstr
    I havent used Ugs, but found this via a quick google: Platform alarm reset? How to do it. · Issue #601 · winder/Universal-G-Code-Sender So it looks like this was solved in a later version of Ugs. Side note: Every other ui I've used has a clear alarm button.
    I dont think I fully understand your second question. Are you asking about a command for continuous jogging or perhaps moving in x an y at the same time? If so, both of those are handled by the device you are using (pendant for example).
  3. Evan Leavitt
    Alarm reset perfect thank you. With the second question not necessarily x & Y at the same time, that would be nice, but more continuous movement yes. Thank you for the info.
  4. sharmstr
    As far as I know, I'm correct in that whatever pendant you are using needs to handle figuring out that you want continuous movement. Like if you hold a button down, use an MPG wheel or a joystick.
  5. sharmstr
