TrueUp Bold
Discussion in '3D printers' started by Keith Davis, Sep 23, 2017.
  1. Keith Davis
    Keith Davis Veteran
  2. Anthony Bolgar
    Anthony Bolgar Journeyman
    Thanks for sharing Keith. Could this version be expanded to a 300 X 300 mm bed?
  3. Keith Davis
    Keith Davis Veteran
    I see no reason why not. The arms would maybe need to be extended, but even if the Y rails were attached part way under those Y rails it would be OK really. The big problem is the closed loop Z axis belt. At 100mm wider bed you'd need a 200mm longer belt (816). This 810 should work 784mm or 810mm 2gt endless belt - RobotDigg.
    In fact, I'm trying to get the time to build one 300x300 and offer it from my website. Actually I'm even considering having a detachable 90 degree angle from the front and top so it forms a box for shipping assembled.
    Anthony Bolgar likes this.
  4. martin thompson
    Hi keith
    is there a way to export the green parts as a stl from sketchup
    of do you have them as stl files
    thanks for the great work
  5. Keith Davis
    Keith Davis Veteran
    In Sketchup menu open the Window>Extension Warehouse.and search for STL EXPORT. Select the 3rd one down "Sketchup STL by Sketchup Team". Install it. The Export STL option will appear on the Menu>File group along with an Import option that can import STLs.
  6. martin thompson
    Thanks for the quick reply
    i did that and it exported as 1 big stl
    just wanted to print the green items out
    is there a way to just export the green items into a file for each
    i know i am asking a lot
    the reason i like your version so much is the 2040 v-slot
    i have a uncompleted dbot corexy. which isnt finished and my living arangments now i dont have the room. i didnt realise how big it is
    going to repupose the v-slot and parts to your build
    got it all only have to print that plastics
    cheers
  7. Anthony Bolgar
    If you come up with the plans for the 300X300 version, I would love to build one.
  8. martin thompson
    Just figured out how to extract out of SketchUp
    mine will be for a plate of 250x250
    the more I look at this printer the more I like it a lot
  9. JustinTime
    JustinTime Journeyman
    the stl export option exports only 'grouped' parts. If you have all the pars selected it will export them all in one file. If you click on each part individually, and you see it in the blue cube wire frame (indicating that they are a group), it will export only that part.
  10. Keith Davis
    Keith Davis Veteran
    The best way to export a single part is to click on the part all the way down to where you have highlighted the raw part (outlined in blue with blue dots in the faces). That way you know you have drilled down through all the groups and components)
  11. Keith Davis
    Keith Davis Veteran
    A 300x300 requires no changes in printed parts. Cut the 2 Y axis rails an extra 100mm long and extend out over the front. The Y belt does not need to be a closed loop belt. I use 200x300 beds in my shop and they are done this way. You might want to add a front piece bridging those two Y rails but it's not really necessary.
    Cut the 20x60 center bar 100mm longer and the top 20x20 rail 100mm longer and use a 900mm close loop belt for the Z axis. Add 100mm to the X axis bar when you cut it too. The X axis belt does not need to be a closed loop belt.
    Twopan likes this.
  12. Keith Davis
    Keith Davis Veteran
    Martin, for a 250x250 plate look at te instructions I just gave Anthony for a 300x300.
  13. martin thompson
    Fantastic thanks keith
  14. Anthony Bolgar
    Thank you. I will post the build once I have made it.
  15. Anthony Bolgar
    Can you post the STL's Keith?
  16. Keith Davis
    Keith Davis Veteran
  17. martin thompson
    Thanks keith for your great work
  18. Anthony Bolgar
    Thanks Keith....fast response as always!
  19. martin thompson
    Hi Keith
    great work on the stl's thanks again
    can i trouble you if you have the time to post a couple of real-life photos of the bold of a link to some
    i am at the build stage just wanting to get a better idea the 3d pics are great but real time photos are good
    thanks in advance
  20. Keith Davis
    Keith Davis Veteran
    Sorry Martin, I do not have any photos or vids of the Bold. I built it on request for a customer and didn't think to take camera to it before shipping it.
  21. martin thompson
    No worries
    Do you stock the mds nylon rod
    Carnt find anywhere in Australia
    And Amazon won't ship
    I can buy and ship to a us address then need somebody to cut into quarters and post to me
  22. Keith Davis
    Keith Davis Veteran
    Martin
    I have 4 nylon rods that are already cut the right length. They are not the MDS, I don't use MDS on my own TrueUp glides, that was actually just for advertising since I had some MDS from another project. These are 606 nylon.
    Give me that usa address and I'll ship them.there, no charge
  23. martin thompson
    Mate thanks I'll get it now
    Here you go
    United States
    Name
    SM-2172-9584 MARTIN Thompson
    Address line 1
    14601 North Bybee Lake Court
    Address line 2
    Suite SM-2172-9584
    City
    Portland
    State
    Oregon
    Zip
    97203
    Phone number
    (503) 736 5916
    Cheers this mob will ship to me in Australia and I pay postage here
    Thanks again
    #23 martin thompson, Apr 29, 2018
  24. Keith Davis
    Keith Davis Veteran
    Martin
    I'll have that in the mail tomorrow morning. Glad to help.
  25. martin thompson
    Mate back to you
    I can't wait to get your design up and running
    Looks smooth and sleak
    Keith Davis likes this.
  26. martin thompson
    Keith a very big thanks just got a confirmation email that auspost has them and are on there way.
    Just a couple of questions
    1. the 8mm o/rings where do they go.
    2. the 4 8mm locking rings for the threaded rod, what did you and where did you get them from
    I ordered what I thought they were and they came and the od is way to big and high to use
    thanks again
  27. Keith Davis
    Keith Davis Veteran
    Martin
    The bearing on the very bottom of the 8mm Z screw is in a bracket recess. If you jab the pulley up against that bearing to keep it in place the pulley will engage the outer race of the bearing instead of the inner race. A washer is needed between the pulley and bearing that is the OD of the inner race. I use an o-ring. You cannot find washers that will do the job. But you can print one. 2mm high, 13.5mm OD, 8.5mm ID should do it.
    The lock collars are from Openbuilds. On my first one I didn't have any lock collars so I instead used 2 M8 metal nuts, one jabbed against the other for each lock collar. You probably will not need a washer between the bottom nut and the bearing inner race below it, nuts tend to be small enough outside size to fit the inner race
  28. Twopan
    Twopan New
    Hi Keith, I've been following your builds since I first saw the OneZ. The single stepper running 2 lead screws is what caught my eye. I think I finally have enough knowledge to give one of your designs a try. I like the idea of a 300 x 300 Bold. I will be taking my time and I'm printing off a highly modded Tevo Tarantula at the moment. How tall can I go with the Bold. I'll be using 2040 in place of the 2020's everywhere except for the front to connect to the 2 side pieces. Maybe overkill but I like it sturdy.
    Jim
  29. Keith Davis
    Keith Davis Veteran
    The guy I designed the Bold for took his up 18 inches.
  30. Twopan
    Twopan New
    Hi Keith I left a message about the stl's for the bold in the wrong discussion group. Sorry about that. Too many tabs open.
    Jim
