Trouble with y axis
Discussion in 'CNC Mills/Routers' started by jbell, Mar 10, 2020.
  1. jbell
    jbell New
    My open builds black box has been trouble free for the last few months and now the y axis is not holding its settings. During the cut it moves out of position by .25mm. I set it to the right spot and zero it out and run job. When the job is finished I return it to zero position and the y is not in the proper spot but both the other axis are correct.
    Can anyone help me with this problem?
  2. Alex Chambers
    Can we have some more info please. What machine is this - is it belt drive or leadscrew. As a wild guess I would suggest the first thing to check is the motor coupling/drive pulley fixing to the motors. Whatever it is more likely to be a mechanical problem than electronic.
  3. David the swarfer
    check for dirt on the Y axis rails and on the wheels.
