Trouble installing Update v1.0.307
Discussion in 'OpenBuilds Bug Report' started by MA_CRDSGN, Dec 1, 2021.
  1. MA_CRDSGN
    MA_CRDSGN New
    Hi,
    I'm trying to update the Openbuilds control to version v1.0.307 so that openbuilds CAM Gcode generator can interact with it and it doesn't work, it keeps installing the v1.0.305. This makes it impossible for the Gcode generator to connect to the control.
    Thank you
  2. MA_CRDSGN
    MA_CRDSGN New
    this is what it keeps on doing
    Uninstall and cleanup the old install first - sometimes the uninstaller get stuck if your computer lost a couple temp YAML files since the install last ran :)
    A clean install will sort it out: OpenBuilds Software - FREE Software for CNC Control: OpenBuilds CONTROL and OpenBuilds CAM
    PS: v1.0.308 is out too: OpenBuilds CONTROL Software
  4. MA_CRDSGN
    MA_CRDSGN New
    Hi,
    I am getting the same problem, even with the version 1.0.308, I even uninstalled the older version and cleaned everuthing up and it still does it
    Then there is still remnants stuck (running instance? Reboot) that you didn't clean up
