Touch probe help needed
Discussion in 'Control Software' started by Rob Atha, Dec 30, 2019.
  1. Rob Atha
    Rob Atha New
    Hi all.
    Just wondering if someone could help me with this touch probe I purchased from Ooznest in the U.K. I’ve seen quite a few of these plates with through holes and apparently it’s used to set up the XY datum position but I’ve no idea how to set it up. Can anyone point me in the right direction please?
    Seeing as its Ooznest, are you using Duet or a Grbl based controller (affects the reply sorry need to know)
  3. Alex Chambers
    As @Peter Van Der Walt said, but also if Duet what version of the firmware - big changes recently.
  4. Rob Atha
    Rob Atha New
    I’m using the xpro v4 rather than the duet,
  5. Alex Chambers
  6. Rob Atha
    Rob Atha New
    Thanks Alex. Will have a look
