Top Down Resin Printer
Discussion in '3D printers' started by AndreMerc, Jul 17, 2017.
  1. AndreMerc
    AndreMerc New
    hello,
    I'm currently building a top down printer and I want to implement a wiper system. I'm looking to use a mini-v or the belt driven actuator. The only thing is That I'm not sure how I would install it on the frame. The red line is where I would like to have the actuator installed.
    Would anyone have examples of an installation similar ? Any advice on the implementation of it? (I still need to figure out how to run it using nanodlp)
    Thanks for any help
    Andre
    #1 AndreMerc, Jul 17, 2017
  2. Mark Carew
    Hello @AndreMerc If you want to keep everything enclosed within the frame (which I suspect you do) and you only have to move a short distance, I would suggest implementing the Nema 17 Belt and Pinion system
    There are example file to choose from in the Files and Drawings tab
    AndreMerc likes this.
  3. AndreMerc
    AndreMerc New
    Mark, that would work perfectly on my build, thank you.
