Tolerance issue: HELP
Discussion in 'CNC Mills/Routers' started by P.Abraham, Dec 4, 2020.
Tags:
  1. P.Abraham
    P.Abraham New
    Hi there,
    I’m having an issue where in my y-axis leadscrews don't travel the same distance. The discrepancy is only about 2-3mm between the 2 sides. but it throws off every cut I make. Tolerances are non-existent.
    Example
    starting from the back of the machine (square and flush with the frame), by the time the gantry reaches the end of travel, Y1 = 1000 but Y2 is 997
    I’ve troubleshooted the following
    1. Tensioning leadscrews
    2. C-Beam length measurement
    not sure if it’s stepper motor current, mm/step calibration (done), something to do with the thrust bearings... proper stuck.
    Any help appreciated
    Check (and loctite) grubscrews on the shaft couplers (motor and leadscrew sides both)
  3. David the swarfer
    and balance the current settings, ie make them both the same for Y and Y2
    Christian James likes this.
