tinyg issue with GRBL Panel + UGS question
Discussion in 'General Talk' started by gazingm42, Feb 26, 2017.
  1. gazingm42
    gazingm42 New
    So got my unit built and have my tingy g connected on the desk with power supply and PC.
    I able to connect via coolthread console and send command on com4 fine. Ran $test=1 and performed
    a smoke test and turns the motor 1 (X-axis) fine.
    I downloaded GRBL panel and able to connect and see the Tinyg> OK in the console. But not able to hit the
    x+ x- to move the motors.
    So I tried universal gcode sender. It works fine with com4, able to X+ X- fine. But the reset or zero axis says
    not implemented yet. So is there a gcode you can use with USG to reset or set your home to once you move it
    on your project?
