The Haus
Discussion in 'CNC Mills/Routers' started by jkenn13, Apr 9, 2015.
  1. jkenn13
    jkenn13 New
    jkenn13 published a new build:
  2. Jamie McShan
    This looks like exactly what I am wanting to build. Can't wait to see how this turns out.
  3. Jamie McShan
    Just checking in, any new progress on your build?
  4. john harvey
    looking for any updates on this build as well
    This looks like just what im looking for
  5. Ronald van Arkel
    John and Jamie,
    Looks like it's a dead end here, but, I can tell you that I've build a similar machine when the C-Beam was not released yet. The idea what you see here to use 2 standard V-Slot gantry plates was used in my build as well and I can tell you that it holds up perfectly, especially with the V-Slot going from one plate to the other reinforces those plates tremendously (and was needed as well). Reducing the Z-axis height will make this build a lot more stable. Personally I would not go over 100mm of Z-axis travel and use the new anti-backlash Acme blocks. you can also use 2 Acme blocks, one on every gantry plate on every side of the X-axis; this will reduce vibration (at over 2000mm/min) and even a bit more of backlash.
    -Ronald
  6. vickers20
    vickers20 New
    hey just wondering if you could share the parts list you used to build this machine. I really like this and would like to give it a shot. Any chance you could sare this.
  7. JerryD
    JerryD New
    Also inspired by your build. Any deflection issues with the tall gantry supports?
