The Growler
Discussion in 'CNC Mills/Routers' started by Scott Martinez, Feb 13, 2019.
  1. Scott Martinez
    Scott Martinez published a new build:
  2. gta18
    gta18 New
    Hey those are monstrous motors! Been looking for servomotors that'll replace my nema 23's on my 1500x1500 build.
    Currently I have 2505 ballscrews that I think I oversized. Now I can only run the gantry maxed out without load at 3800mm/min, once Im cutting lets say 3/4 plywood, I can only go about 2400 without losing steps.
    Which motors did you go with? Do you mind posting the part numbers?
    Thanks!
  3. Scott Martinez
    Not at all... I will upload a BOM once I get it finished. These are the motors that I used:
    X axis: CPM-SDSK-3411S-RLS
    Y axis: CPM-SDSK-3432P-RLS (x2)
    Z Axis: CPM-SDSK-2331S-RLS
    They all have a top speed of about 2400 RPM. The screws are 5mm lead which is a theoretical top speed of 12,000 mm/min.
    -Scott
  4. gta18
    gta18 New
    Cool thanks! I can't wait to see your machine running!
    I haven't seen anyone use these motors.
  5. Project Hopeless
    Scott,
    On your gantry/beam the linear bearings, are they threaded directly into the aluminum extrusion? What extrusion profile are you suing to support the bearings?
  6. Scott Martinez
    Yes, the rails are bolted directly to the 80/20 extrusion. The profile is part number 40-4080. I'll be adding the BOM soon, which has all the part numbers.
    -Scott
  7. TurfnSurf
    TurfnSurf New
    Wood couplings for the win?
  8. Scott Martinez
    Wood couplings? No, the couplings are definitely not made of wood. :thumbsup:
  9. TurfnSurf
    TurfnSurf New
    Perhaps my choice of language is poor - connectors, connecting the ballscrew bearing blocks to the aluminum channels.
  10. Scott Martinez
    Ah yes, I see what you mean. When I was first beginning to assemble the machine i thought "I'll make these parts out of wood for now, then replace them with aluminum parts after I prove out the design.". I may still do that, but only if the wood parts fail or if I find a good reason to. If I find that the bearing block is moving, that would be a good reason.
  11. TurfnSurf
    TurfnSurf New
    At least in my application, I find that more of the movement comes from the poor quality chinese bearing blocks than the connection itself. I'm sure if I needed more torque, that I couldn't get away with wood. Seemed kind of funny (in a good way) to me for some reason when I saw your use of wood components. Sounds like a good plan, replace with aluminum at your leisure. Will be neat to see it in action, keep us posted! (now if only I remembered how to "follow" a project on this website...hmm)
    #11 TurfnSurf, Feb 17, 2019
  12. Project Hopeless
    Scott,
    I have a build in the planning stages that looks very much like yours.
    I understand on the gantry the vertical board handles any Z deflection. How about X (bed travel), is there any applicable bowing of the beam under load? I was thinking of building a torsion box beam/gantry with extrusion mounts for the bearings. But if I don't need to that saves me some weight and time.
    I see you have upgraded the spindle. What depth of cut and in/min. rate can you run?
  13. Scott Martinez
    So far I haven't pushed it very hard, so I haven't had any trouble with any parts of the machine moving under load. But now that you've mentioned it I am curious about how fast I could push it. What would be a good test? The max feed rate is going to be about 250 IPM.
  14. Scott Martinez
    So I did a few test cuts yesterday just to get an idea of what this thing can do. I used a 1/4" 2 flute upcut router bit in a piece of 2 x 6 construction lumber. These were the cuts I made:
    0.050" deep at 200 IPM
    0.250" deep at 150 IPM
    0.500" deep at 100 IPM
    0.750" deep at 50 IPM
    1.000" deep at 25 IPM
    The only issue I saw was a lot of chip re-cutting at the two deepest cuts. I assumed this was caused by the fact that there was just no place for the chips to go. The machine did the cuts with no problem, no slowing of the spindle speed or any other signs that this was too much for it.
    I was thinking that a good test would be to cut a series of circles at different feed rates and DOC. If there is any significant flexing of the gantry then this would result in the circles being smaller in one direction than the other.
    -Scott
    GrayUK likes this.
  15. mohamed1010
    mr scott
    how i get the mdf cutting plan to prepare to get this machine
    [email protected]
  16. Scott Martinez
    There is a full 3D model and bill of materials available under the "Files and Drawings" section of this build.
    -Scott
