The best way to clean the aluminum rail
Discussion in 'General Talk' started by hosa200, May 13, 2016.
  1. hosa200
    hosa200 New
    Hello guys,
    I want to know what is the best way to clean the rail from dust and chips .
  2. Barry Danks
    Barry Danks Well-Known
    I use an old 1 1/2 paint brush and alcohol
    hosa200 likes this.
  3. GrayUK
    I do my decorating that way as well. :rolleyes:
    I don't mind if it's Scotch or Vodka? :D:D
  4. Ronald van Arkel
    hosa200 likes this.
  5. hosa200
    hosa200 New
    the rail sometimes get some scratching which affecting the wheel
  6. Ronald van Arkel
    Hello @hosa200,
    I can't find the topics, mostly about the OpenBuilds Ox, in this forum to show you how to keep the rails clean before a wheel rolls over it, but I can tell you how it's done. They cut a door brush into pieces and place them before the wheels:
    I hope this helps.
    -Ronald
    Daragh and hosa200 like this.
  7. Joe Santarsiero
    Joe Santarsiero OB addict
    Shielding and a dustboot help too.
    hosa200 likes this.
  8. hosa200
    hosa200 New
    I don't understand:(
  9. Ronald van Arkel
    Better to take some pictures of your machine so we can also see what you are talking about.
    hosa200 likes this.
  10. hosa200
    hosa200 New
    here
  11. Ronald van Arkel
    I would clean it with WD40 and a cloth, that brush I was talking about are made to put on the inside down on a door. The brush isn't sold all over planet earth so you might never have seen it before and probably not sold locally. It can be cut into peaces and placed before the wheels with an bracket. Still you need to do maintenance like you now have to do on your machine.
    What is that sticky stuff on the V-Slot?
    -Ronald
    hosa200 likes this.
  12. hosa200
    hosa200 New
    it might be tape or sticker (the rails are used )
  13. Ronald van Arkel
    WD40, perfect for cleaning sticker residue/glue ;).
    Joe Santarsiero and hosa200 like this.
  14. hosa200
    hosa200 New
  15. Anthony Bolgar
    Anthony Bolgar Journeyman
    Careful using any cleaner on the rails if you are using the Xtreme v wheels, they recomend using only a silicon based lubricant. SO make sure any cleaner you have used it rinsed off or it will degrade the Xtreme wheels.
    Mark Carew, hosa200 and GrayUK like this.
  16. MaryD
    MaryD OpenBuilds Team
    Ronald van Arkel likes this.
  17. Ronald van Arkel
    Hand Cleaner, who would have thought of that. I can imagine that it's not sold all over the world so what would be the active component in the cleaner? This will save my day every time v-Slot / C-beam comes in ;) !
    -Ronald
  18. MaryD
    Looks like it's got a pumice in it but not sure what else makes it work so well. Check out the ingredients here: Permatex® Fast Orange® Fine Pumice Lotion Hand Cleaner - Permatex
  19. Ronald van Arkel
    Yeah, I´m reading the PDF files for Canada. For sure I need to try this out and see if it does better than WD40 :).
    -Ronald
    MaryD likes this.
  20. GrayUK
    Sounds similar to what we used to have in the UK, which was Jiff. However they changed the name, I think it said something rude in anther language. We can still get it, but I can't remember its name. It was a good cleaner, but maybe too course for aluminium.
    Gray
    MaryD likes this.
  21. Ronald van Arkel
    Yes, Jif, brand by Unilever (the darn Dutch again ;) ). Brand was registered in some countries so they had to change it. I can get it here too in Mexico under some name just not Jif. I believe it's a bit different than the hand cleaner, more like an abrasive powder in a cream. The Jif brand by Procter & Gamble is used for peanut butter in some countries. Jif cleaner is now also named Cif and Vim.
    Still, it's different
    Just got back from lunch so now it's time to look trough those PDF files :D.
    Edit: I see that PUMICE is indeed a stone used in other abrasive cleaners, but not in Jif (my bad). So there is no way to get deeper scratches out, and like Mark said it's just to make the wheels run smooth again. The cleaning component left must be the "rubbing alcohol" as the water only cleans a bit.
    So NEODOL alcohols and ethoxylates are an example of those cleaning or rubbing alcohols.
    "Jif" has:
    Sodium Carbonate 497-19-8 <10%
    Anionic Surfactant 25155-30-0 <10%
    Nonionic Surfactant 68439-46-3 <10%
    1,2-Benziothiazol-3(2H)-one 2634-33-5 <1%
    Fluorescer (Jif Regular Only) - <1%
    Fragrance Ingredients - <1% (like we care if it smell good, lol)
    #21 Ronald van Arkel, Aug 25, 2016
    GrayUK likes this.
  22. eddiejr
    eddiejr New
    I was gonna say "brake cleaner" as I believe it doesnt leave a residue.
    GrayUK and Ronald van Arkel like this.
  23. Ronald van Arkel
    That and a beltsander! :D
    GrayUK likes this.
