Tab and slot construction
Discussion in 'Other Software' started by jeffmorris, Sep 2, 2019.
  1. jeffmorris
    jeffmorris Journeyman
    I downloaded drawings for a model car that uses tab and slot construction. I have VCarve Desktop software and when generating tool paths, the slots don't show up on the preview window. The model car needs 1/8" or 3mm plywood and I have 1/8" bits. Any suggestions?
    Post the DXF, or some screenshots :)
  3. jeffmorris
    I lied to VCarve Desktop that I'm using 2.9mm bit and after generating the toolpath, all the slots show up on the preview window.
  4. jeffmorris
    I made some test cuts and found out that the slots are too short for tabs. I have to draw lines in center of rectangles and delete the rectangles. I will make some test cuts and see if the slots are long enough.
    MaryD likes this.
  5. phil from seattle
    phil from seattle Journeyman
    Are you dog-boning/t-boning your tabs? The radius of the cutter will affect your tabs and prevent a flush fit. You can make the slots longer by the diameter of your cutter but that is sometimes undesirable. A T-Bone will make room.[​IMG]
