Stepper problem: Ramps 1.4 + Marlin + Nema 17
Discussion in 'Motors' started by elib, Nov 30, 2016.
  1. elib
    elib New
    Hello,
    I'm currently working on a new 3D printer based on this OpenBuilds project (Voxel OX - Extendable 3D Printer and CNC Platform)
    What I'm using:
    - Ramps 1.4
    - Nema 17 stepper
    - 12v 19amp power supply
    The problem is that the steppers don't seem to work correctly. When I test them, some only works when moving with 0.1mm steps and stop moving when moving by 10mm.
    I'have also noticed that the noise coming from the stepper is a bit loud.
    I don't know what to test or where to go to fix my problem. Could you please give me some advices?
    -> Extruder doesn't move at all
    -> Some stepper look like being more precise and constant
    -> I can provide you video if needed.
    -> I have already play with the potentiometer on the Polulu
    Thanks for your answer!
    Edouard
  2. Anthony Bolgar
    Anthony Bolgar Journeyman
    Please post the video.
  3. elib
    elib New
    Hello,
    Here are 3 videos presenting the 3 axis. I'm sorry for the quality and exposure. It's maximum light in my desk and my smartphone is very ****** (I'll get a new one soon and could provide you then new videos if needed)
    But the main problem is presenting: the noise and the way parts move.
  4. Krashlnd
    Krashlnd New
    To me it sounds like your steps are set wrong. Tell any of the axis' to move 10 mm (at a slow rate as not to miss a step) and measure how far it moved. If you need help setting the steps in the marlin firmware I can help you. Also adjust the vref of each axis.
    Steve
