Stepper motor RPM calculator
Discussion in 'Helpful Tools' started by Dr.O, Apr 26, 2018.
  1. Dr.O
    Dr.O New
    Stepper motors are normally used for positioning, and are not known for their speed.� This calculator computes the maximum speed of a stepper motor, which is limited by the time it takes for the coil to energize to it's maximum holding current, and then de-engergize as polarity flips
    Stepper Motor Calculator
    Can be used to calculate optimal feed rate for work with load which is 50-60% of max RPM
