stepper motor is 2.8 amps controller allows 3.0 or 2.6 amps.
Discussion in 'General Electronics' started by ZacharyB, Dec 18, 2017.
  1. ZacharyB
    ZacharyB New
    I purchased 3 stepper controllers that have dip switches which allow me to regulate the amps.
    https://www.pinterest.com/pin/620511654881622915/
    The closest I can come to configuring it properly for my 2.8 amp stepper motors is 3.0 amps or 2.6 amps.
    https://www.amazon.com/dp/B00QG1ZF48/ref=cm_sw_r_pi_dp_U_x_OPdoAbG3S3NF8
    Is it ok to set the controller boards to 3.0 or should I set them to 2.6 amps?
    The Electronics 101 post said it's best to set the amps exactly as the motor specifies, never higher. But that is not an option.
  2. Gary Caruso
    2.6 would be fine, at 3 they might run too hot. Hot is when you can not hold your hand on it for more than a few seconds. Warm is just fine.
    ZacharyB likes this.
  3. Joe Santarsiero
    Joe Santarsiero OB addict
    Set them to 3 and keep and eye on temperature. If any are getting too hot to touch then turn the driver down for that motor.
  4. ZacharyB
    ZacharyB New
    What is the benefit of supplying more amps? Does it give it more torque or speed? Please educate me. Thanks
  5. Gary Caruso
    Basically current is torque voltage is speed.
