Step Direction Invert.
Discussion in 'Control Software' started by jda70az, Jan 22, 2021.
  1. jda70az
    jda70az Well-Known
    How does this work exactly?
    If I set it to Invert X and press the X + button on the Interface will it move to the right
    and Invert Y and press the Y+ button move away or to the back of the machine?
  2. Alex Chambers
    It will do the opposite of what it does now. X +ve should move right, Y +ve should move back and Z +ve should move up. What happens when you jog each axis +ve now?
  3. jda70az
    jda70az Well-Known
    When I press the X+ button on the Interface box it goes to the left side of the machine
    my GRBL settings are $3 no Invert on all axis.
  4. jda70az
    jda70az Well-Known
    Never mind I fixed it.
    It was flipped wiring on the 4 pin connectors.
