Start point does not meet end point, "Circles"
Discussion in 'Laser Cutters' started by pedrofernandez, Mar 7, 2018.
  1. pedrofernandez
    pedrofernandez Journeyman
    IMG_0238.JPG Need help with my Acro build with this issue thanks
  2. Kevon Ritter
    Kevon Ritter Veteran
    It looks like backlash in the x direction. Make sure everything is tight and secured.
  3. pedrofernandez
    Hi thanks for the reply, but I have a cbeam machine a Sphinx and a mini mill and i have everything very tight and secure but this is my first time dealing with a belt driven system, i have is this one the 14t timming pulley gt2m timming belt the assembly video the person used a 16t timming or maybe my step jumpers are wrong, but squares and other shapes are ok i think.
  4. David the swarfer
    what you show in the pictures is definitely backlash.
    make sure that one of the set screws on each pulley is resting on the flat on the motor shaft.
    make sure the setscrews are tight but have not stripped the threads.
    make sure the eccentric nuts are correctly set
  5. pedrofernandez
    Will double check the set screws but this build do not have eccentrics at all.
  6. David the swarfer
    no eccentrics, but it does have adjustment slots. if there is play in one side then the X can tilt as it moves....
  7. pedrofernandez
    Problem solved, readjust all wheels and plates now we have real circles thanks.
