Spindle mount to allow tramming
Discussion in 'CNC Mills/Routers' started by Apeli, Feb 10, 2020.
  1. Apeli
    Apeli New
    I need to tram my router/spindle to get it level. It's not far from level, but I can't find any simple ways to adjust it all the way. So I have been trying to come up with a router mount that would allow tramming adjustments. I came up with a plan:
    - Add a collar to the bottom of the router body, just above the collet. This isn't attached to the Z-axis.
    - The actual mount has 4 screws that go vertically through the mount and touch the collar.
    The idea is that you could tighten the mount 95%, use the screws to tram the router head and then tighten the mount 100%.
    Anyone tried something like this? Anything wrong with my reasoning?
    Alex Chambers likes this.
  2. Alex Chambers
    Interesting idea. I would love to see a drawing. I had an idea for the same problem (couldn't work out how to hold the router & mount still while tightening) a while ago - Tramming aid - but I never got as far as making an aluminium version. I think you're idea sounds better than mine.
    Suggestion:
    Router mount can be used to tram left-to-right. But fixed reference of X gantry is good!
    Then tram X gantry to Y rails (slightly loosen end plates)
    Square Y rails, then surface spoilboard. That's it! Done :)
    Key here is people forget you can tweak the X axis extrusion's rotation ever so slightly, to tram back-to-front :)
  4. Apeli
    Apeli New
    Oh well, it didn't work. Basically the main clamp needs to be 100% tight and when it is 100% tight, all the micro adjustments you could do with the screws are gone.
    Adjusting the rails / end plates gets harder with a larger machine, my X is 1900 mm and Y 870 mm, and the taller OX Y-plates I just got have so little play in the bolt holes that I can't use that to get to 100% level.
  5. Logan Blankenship
    @Apeli did you ever figure out a solution for this? I have the lead machine but am having trouble tramming my router front to back. Would like to hear if you figured anything out!
  6. Apeli
    Apeli New
    No, ended up upgrading my spindle mount, which allowed tramming with "normal" methods, shims etc.
    Logan Blankenship likes this.
  7. Logan Blankenship
    I ended up getting mine close enough for my needs. But out of curiosity which mount did you upgrade to?
  8. Apeli
    Apeli New
    I got some 12 mm aluminium plate for the Z gantry and a "Funssor 43 mm Kress spindle mount" for the mount. I drilled one of the mounting screw holes a bit oversize to allow left/right tramming.
