Spindle Mount anyone?
Discussion in 'General Talk' started by Dekes1, Apr 1, 2015.
  1. Dekes1
    Dekes1 New
    My Ox is currently using the QuietCut 400W spindle with a sturdy but ugly DIY mount. I'm looking to 3D print a better mount. I searched Thingiverse but most of the mounts are for 20/40 rail spacing and Im using 20/60 rail on the Z . the spindle is 52mm in diameter - does anyone have a 3D model they'd be willing to share?
  2. Joe Santarsiero
    Joe Santarsiero OB addict
    If you send me a drawing or a model to be modified I'll do it. I thought all versions were floating around here though.
  3. sasquatch437
    here are some stl's of a mount i printed for mine till i can get running and make one might keep these
    not pretty but they hold my 400w brushless spindle fine
  4. sasquatch437
    sorry i just saw you have 20/60 rail mine are 20/80, if you want i can do one and send you the stl
  5. Dekes1
    Dekes1 New
    sasquatch, as i'm still in the learning phase of 3d modelling and design, it would be most welcomed if you remixed one that would work with 20/60. Thank you!
  6. sasquatch437
    how would you like it uploaded as a .dwg model, .step or i can upload the stl files let me know they are just about done
  7. sasquatch437
    hello
    i also need to know how you are going to mount this is it to a plate or right to a piece of 20/60 and can we wrap around to the sides if it is a piece of 20/60 will have it done wednesday afternoon
    thanks ed
  8. Dekes1
    Dekes1 New
    The stl files would be fine, and yes I'll be bolting it right to the 20/60 rail, no plate. Thanks again
  9. sasquatch437
    have a look at these the rear can wrap around the side for 4 more bolts or use the one without side wrap
    the front will fit either i used openbuilds screws and slot nuts for my hardware alsi i printed PLA with 70% infil, solid no flex
    youre welcome if you need adjustments let me know
  10. Dekes1
    Dekes1 New
    Awesome sasquatch! Printed this afternoon and works beautifully. Went with 100% infill for stiffness and it's probably going to stay as my mount until i upgrade the spindle. Thanks again
  11. sasquatch437
    sounds great glad to be able to help
