[solved] Strange behaviour of a blackbox controller when using too high feedrate
Discussion in 'CNC Mills/Routers' started by Gerd Schelbert, Mar 15, 2020.
  1. Gerd Schelbert
    Hi, folks.
    I recently built a sphinx55 using a blackbox v4-controller.
    Actually i am testing and finishing the Mill. Today i encountered a strange behaviour:
    Homing with 3 axes works like a charm, jogging around between the edges works well. Horizontal and vertical movement (x- and y-axis) works up until 7500 mm/min.
    But the mill reacts strange when working with diagonal movement. if i try a "G0 X150 Y150 F1000" after homing, the steppers on the y-axis starts screaming und loosing massive steps. The X-axis movement seems to work correct.
    I checked cabling several times but all looks good.
    Any clue?
    Best regards
    a slightly clueless
    Gerd Schelbert
  2. Gerd Schelbert
    Looks like i've found the reason:
    7500 mm/min seems a bit too much. With 4000 as max xyz the mill works well again.
