So many options and questions
Discussion in 'General Talk' started by heavyweather, Aug 25, 2016.
  1. heavyweather
    I want to build a 1400mm*900mm working area router and need some decisions first.
    The table will have a vertical mounting plate on the end or possibly somewhere in the last 2\3 so tgat you can work on higher pieces.
    Belt&pinion or r&p on the x+y axis?
    I like the simplicity of the b&p design and just saw the double belt setup with interlocking belts. How does that compare to r&p (or screw)? Is there any drawback compared to R&P?
    Leaning toward the double belt drive from the stainless OX.
    Flexing.
    Is mounting the aluminium profiles to a steel frame (just using thin profiles as running guides/rails) an option? I figure I can buy cheap profiles and just screw them to steel with t-nuts (all 3 axis) for maximum stiffness. I just happen to live next door to a steel/metal seller.
    Will the Nema 23 carry all the weight when I use steel plates also?
    Source for parts.
    Can only Openbuilds profiles be used with V-Wheels or will they also run in other extruded aluminium profiles sourced locally? Also V-Wheels. One Wheel is around 4€ here and I can buy 20 Wheels on Aliexpress for ~20€.
    Z Axis
    I might buy a ready made screw actuator for that. Good idea?
    Plates.
    Which material makes sense? Aluminium or steel? I tend to use steel if it is not too heavy? 6mm steel?
    Spindle
    Got a 700C Makita router/trimmer but not sure if I want to use a Kress 1050 instead or even a water cooled spindle.
    I want to cut mostly wood, my father and father in law might cut some aluminium.
    Electronics
    That's where I will start...want to get the steppers running before building the mechanics.
    4 Nema 23 motors? Separate controller for each. Which set (from Aliexpress possibly).
  2. Giarc
    I used 1500mm v-slot 2080 for the y axis and a doubled up 2080 at slightly less than 845 mm for the x axis for my build and only got 1277 mm by 667 mm of usable work table (which was expected after modeling it in Sketchup). That is 26.25 inches by 50 inches. My goal was to be able to cut 26 x 48 inches for cabinets. I could have made it wider by using the full 1000 mm v slots for the x, but I wanted it to be as rigid as possible while being able to cut the specified size, and the machine already takes up a ton of space. Also, I want to build an egg-bot and the cut-offs will work perfectly for it. ;) I chose 1/2 inch acme screws from McMaster Carr for the Y. I get no screw whip at 5000mm/min speeds. Here is a link to my build. Lead Screw Driven Ox Derivative (850x1500) The sketch-up file has been modified numerous times and I haven't had a chance to update it. Many things have remained the same most importantly, the length and width. There is an updated sketch-up picture in the build showing how I tied the Y axis to the torsion box table.
    As for flexing issues, my system seems to be very rigid. The weakness (of course) would be the z. To help eliminate that, I have different thickness spoiler boards I can mount to raise the material closer to the x axis.
    I use a Makita router and am surprised how quiet it is. I really like it so far. For electronics, I used an Arduino with a shield and DRV8825 drivers. However, I am currently upgrading to steppers like Openbuilds sells. I bought them last fall prior to Openbuilds selling them and I paid the same is what the OpenBuilds Parts Store sells them for, but had to wait a lot longer and had to worry about them being Wantai knock-offs. Luckily they weren't...I think.
    I believe the v-wheels were designed for the v-slot rail only. Others may know better.
    heavyweather likes this.
  3. Joe Santarsiero
    Joe Santarsiero OB addict
    If you're going to start with electronics first then spring a little extra for a higher overhead. The DQ542MA's sold here in the store max at 4.2A which is plenty enough to run any nema 23. You may find out later that your motors need to be replaced by ones with more desirable characteristics to accomodate your machine. 2.8A-3.2 is a common range for these motors and many of the hobby combo driver packages have a hard time maximizing full use of the motor. A 4A driver is plenty enough without overkilling it. If you're considering adding mass with steel parts later on then deff invest in the electronics and don't think you'll be getting away with hobby combo boards like an Xpro or TG. I spent $30 to learn this lesson.
    Z-axis. Yeah. If you find a good slide for a Z then go for it. This is what I did. There are a lot more options for this on eBay now compared to even 3 months ago and the prices are getting real competitive.
    Plates. Plenty of builders are using aluminium to mill aluminium. The C-beam consist of aluminum and mills it just fine. Look up The Hog build. Toolpaths are another key part to this. You'll need a piece of software (and learn it) to allow you to maximize efficiency of your machine. This comes with a bit of trial and error by pushing its limits. Just like with a new car. It's even more true with one off machines (think custom car). I highly recommend learning fusion 360. It puts professional toolpaths that are on par with Mastercam and the like and places them within reach of everyone just wanting to learn, do hobbies, or begin to start a small business and at the cost of nothing. It's more than capable enough to run a business with and seat costs for commercial use is ridiculously cheap. So you would be ahead of the curve if any of your projects kicked off. I spend a bit of my professional time in SW, AC, and MasterCAM and I'm sold that Autodesk is playing a really hard long game with this one.
    Spindle. Just as others are already doing, you'll get away with occasional Al. work with the routers. To me the sound and weight are the biggest factors here. I choose a lightweight .8 kw over a trim router and it's a beast through woods and nonferrous metals and I can talk on my cell just fine while it's running with no vac. Admittedly, I am using a top end VFD with fancy bells and whistles and my system is really ridged (much less than .001" vertical deflection with 100lbs above spindle) and I could likely move up to a 3kw, but I don't need that. To me, bigger spindle means more weight, more mass, more deflection, and longer jobs. To combat this can mean more money for better electronics and motors, structural upgrades/downgrades, and ultimately a complete reevaluation of the system in general which is more wasted time. A large spindle on a flexible profile beam could potentially create some stability because of its weight, but once it hits a resonance with the tool speed and cut it's going to be a nasty outcome.
    V-wheels. Just buy OB wheels. The knockoffs aren't guaranteed for quality or consistency. Btw, steel wheels in aluminum profile will quickly upset you.
    Belt vs rack. If you can afford a R&P setup then go for it. Spring loaded is the only way to go. There are some great R&P examples here on the site. Belt in belt systems are also successful. I can't speak much to the limits of such systems. Steel reinforcement. If you have an idea for reinforcing an aluminum frame with steel then please share it. We love seeing individual minds at work and enjoy offering constructive feedback.
    Well, that was my two cents for the moment. I still don't understand what you're talking about as far as the vertical mounting plate for larger work. Do you have any models or napkin sketches?
    Joe.
    Asaf Miller, GrayUK and eddiejr like this.
  4. heavyweather
    Like that table.
    I will draw it but I am away from my Computer that week.
    Steel bearings on aluminium are no option of course. I also don't want to do r&p, don't like the noise and they wear out quicker than the belts I figure. Changing a belt shouldn't be that much a hassle either. The double belt configuration is probably the best solution for my machine now.
    Maybe I will do 2 machines, one big for cutting wood/ply which will be my main task anyways and one heavy, small machine at school (I am a high school teacher) for aluminum and small tasks (30*50cm).
    Has nobody tried glueing steel into a C-beam?
    Also the plates. Why are they aluminum? Because you can cut them on the machine? There is the stainless OX. You could cut the steel by hand or on the scroll saw) and and just use a drill press for the holes.
    GrayUK likes this.
  5. snokid
    snokid Journeyman
    I don't really know why they use stainless, aluminum is just fine.... that's not where there is flex....
    looking at that video there's going to be flex in the z axis with that set up...
    on an ox that rail is 20x60 if you went with 2 c-beams one on top of the other that would help a ton...
    Bob
  6. GrayUK
    Man, that Frank guy is really cool. His workshop is great, and that CNC is something else! :thumbsup:
    He also makes a really professional video. :thumbsup:
    Thanks, I enjoyed watching that.
    Gray
  7. heavyweather
    Frank's CNC is cool. I believe he has a background in Film/Video.
    I've been mulling over my options. still not decided but it seems I am going away from Openbuild. It's a nice system but I can't see the advantage for me.
    Frank's CNC is too big for me but there are some things I like about it. The linear rails with V-bearings for one.
    I don't like the R&P drive. Would like to use steel reinforced timing belts instead like in that one...
    Fräse | CNC14
    They even got an overhang/vertical vice option of 130mm.
    Spannend: Die CNC14 Vise | CNC14
    I could even do more overhang or a bed that can pivot down.
    You also don't need side plates in that design. The just lowered the bed and raised the linear rails.
    I am not sure if 60cm working area is wide enough...I guess it is. There goes the option to carve 90cm doors in one piece...would have never done that anyways I guess.
    For now I am thinking Steel tracks V bearings, timing belts, bought Z axis, my Makita router and some Chinese electronics.
    Maybe aluminium profile for the gantry instead of the multiplex. 4 steel L profiles on the upper and lower T-slots for the rails...
    What about this set? do these USB controllers work?
    mach3 CNC USB 4 Axis Kit, 4pcs TB6600 driver+ USB stepper motor controller card 100KHz + 4pcs nema23 270oz in motor+power supply-in Motor Controller from Home Improvement on Aliexpress.com | Alibaba Group
    or that one?
    CNC Router Kit 4 Axis,4pcs 1 axis TB6560 stepper motor driver+one interface board+ 4pcs Nema23 270 Oz in motor+ one power supply-in Motor Driver from Home Improvement on Aliexpress.com | Alibaba Group
