Smooth Idler Wheel Sizing discrepency
Discussion in 'General Talk' started by Adam Filipowicz, Nov 16, 2021.
  1. Adam Filipowicz
    Adam Filipowicz Journeyman
    When I look at the dimensions listed on the website for the smooth idler wheel it says the ID is 16mm
    when I look at STEP cad file for the part. it says the ID is 17.5mm
    which is correct?
    It takes a 16mm bearing so the answer must be 16mm.
  3. Adam Filipowicz
    I gotcha, So I was misunderstanding the ID to mean the Idler wheel that the belt actually touches, vs the inner hole for the bearing.
    ID for bearing is 16mm
    OD outer edge is 22mm
    and Middle edge where Belt touches is 17.5
  4. Rick 2.0
    Sorry, misunderstood the question. A pdf file from Openbuilds is attached which gives full dimensions but you might want to verify with the shop that it is still accurate.
