slip on/off extrusion end coupling
Discussion in 'General Talk' started by Al Ladd, Jun 27, 2022.
  1. Al Ladd
    Al Ladd New
    I'm looking for the best hardware for allowing 2040 extrusion to be joined end to end in a way that would allow easy slip on/off of one from the other. So something like a dowel tight enough that it could be glued into one of the extrusions, and then the other slipped over the glued pair allowing for a well-aligned coupling that could be fastened by a knob using one of the slots. The application is a table saw fence that will sometimes want an extension piece. I'm thinking maybe #12 sheet metal screws that could be forced into one end, and then ground down on the exposed part for a slip-fit and cut to length, cutting the head off, once installed. Or a hard wood dowel fabricated to fairly tight tolerances, though the required diameter (about .205") is a bit small to be as strong as I'd like. I may need hundreds of these. Thinking someone might have dealt with this issue before.... Thanks!
    Checkout Quad Tee Nut - MAKERLINK (10 Pack)
    Adding them to multiple faces will serve as the complete joint
    #2 Peter Van Der Walt, Jun 27, 2022
    Giarc and Rick 2.0 like this.
