Slaving dual axes
Discussion in 'CNC Mills/Routers' started by Retrosmith, Nov 14, 2017.
  1. Retrosmith
    Retrosmith Guest
    Guest Builder
    [Deleted]
    #1 Retrosmith, Nov 14, 2017
    patdee likes this.
  2. Gary Caruso
    with GRBL you really only have X, Y, Z.. so you just pair up any signals you want you can chain together multiple drivers on any axis no problem.
  3. Flash22
    Flash22 Well-Known
    Its not a issue as its only the control side, power the motors up with the lead screw couplings undone, so the motors can sync with no load - position your axis's by hand and do up the couplings
    I run 2 Y axis drivers and motors and have just set them up
    My double wide CBeam
    patdee likes this.
