Simplify3D and Smoothieboar. They seem to work
Discussion in 'Control Software' started by Val Cocora, Jun 17, 2016.
  1. Val Cocora
    Val Cocora Well-Known
    A little while back I purchased a Simplify3D licence for ver. 3.1
    It seems there were some problems with the software creating junk code which would cause smoothie to freeze.
    One apparent solution is a gcode cleaner but I wanted to see if version 3.1 can deliver without that, so last night I printed a tall tube, 30 mm diameter, 3 mm wall thickness, 150 mm tall, to also test any machine drift. All was printed from a non-cleaned gcode file, and the results are in the pics below.
    20160617_061042.jpg 20160617_061051.jpg 20160617_061101.jpg 20160617_061108.jpg
    I am aware that this is a simple model, will test more complicated ones as I calibrate my machine, but for the time being I must say I'm very happy how everything worked out.
  2. Val Cocora
    also, the title should read 'smoothieboard' not 'smoothieboar'
    my bad.
