Simple sliding door
Discussion in 'General Talk' started by El-d, Sep 3, 2016.
  1. El-d
    El-d New
    hi all,
    I was looking into self build sliding doors as the kits seem to be excessively priced and cheap looking.
    I came across the v slot etc. Can anyone tell me whether using the vslot would be suitable for use as a sliding door mechanism. The doors would be 20-25kg. I was figuring on a u shaped bracket that would fit around the v slot bar and through the wheels and be screwed into the door top.
    Has anyone used this for this purpose and is it substantial enough to cope and provide a good smooth roll?
    El-d
  2. MaryD
    MaryD OpenBuilds Team
    I don't think I've seen a siding door project here before. Be interested in hearing about your project if you go with V-Slot.
  3. snokid
    snokid Journeyman
    it should work no problem....
    Bob
  4. MaryD
    Puneit Singh likes this.
  5. Puneit Singh
    Hello El-d
    did you manage to build this.? I am also planning the same and would like to understand if it works as expected not
