Simple pocket cut I thought....help
Discussion in 'CAM' started by Xxztrexxx, Feb 17, 2020.
  1. Xxztrexxx
    Xxztrexxx New
    Hey all. I needed a simple pocket cut so I drew one up in Cam Creator and this is what happened.
    Hopefully someone can tell me what is wrong as I cant figure it out.. I have done plenty of pocket cuts previously and not had any issues.
  2. terry marwood
    im having the same problem as of this morning
    Pushed a test-fix, please refresh the page and test again.
    If its still not working, please include an OBC (workspace export)
    Thanks!
    #3 Peter Van Der Walt, Feb 18, 2020
  4. Xxztrexxx
    Xxztrexxx New
    Hello I thought this was fixed last time i tried it but once again i am getting this step down ramping on a simple pocket cut. Here is the gcode file and an image off the cut in progress.
    Is there a setting that I'm missing?
  5. Gary Caruso
    Looks like you have 5 passes to get to your final depth. Is this what you are talking about?
    Check your depth per pass and your total material depth.
    Or if the machine is drifting in Z;
    Check your flex coupler to the motor and screw connection, use loctite.
    Make sure the collars are secure against your bearings supporting the screw
    Adjust your driver current higher.
    Gary
