Simple Cnc System (arduino Grbl)
Discussion in 'Laser Cutters' started by viktop, Apr 26, 2019.
  1. viktop
    viktop New
    viktop published a new build:
  2. Tracy Ranson
    Tracy Ranson Well-Known
    I am building a cantilever 3D printer that will look similar. I do not know if you would be able to use this with a router but it does have many other application possibilities i.e. 3D printer, laser engraver, pick-n-place, circuit board maker etc.
  3. Kane49
    Kane49 New
    Hey !
    How long is the X Axis ? I wanted to build one like this but i was afraid of the flex and wobble on the x axis
  4. Tracy Ranson
    With a cantilever that is too long you will need a counter balance and more of a weighted support in the frame work. My cantilever (x-axis) is only 14 inches long but I am only using it for 3D printer with clay and various plastic and I will be using it for my laser module as well.
  5. cdharden
    cdharden New
    What if you added another y beam - then you could go wider!
  6. Kane49
    Kane49 New
    You could also attach a wheel at the end of the X Axis (not a V Wheel, an actual wheel :D) and probably go like 1000x1000
  7. Jamesbil
    Jamesbil New
    Interested to see the progress on this.
  8. Medman
    Medman New
    aren't you going to publish the files for the plates and the mechanism?
  9. Mark Carew
    This would make for a great laser system as well. Nice one @viktop :thumbsup:
  10. abeltcb
    abeltcb New
    interested with your idea.
  11. Keith Davis
    Keith Davis Veteran
    Curios about your 3D printer. Is this sub-assembly moving on Z axis or is the bed?
