Set Zero Point / find Edge with Webcam ?
Discussion in 'CNC Mills/Routers' started by boskap, Sep 9, 2015.
  1. boskap
    boskap New
    Hello
    is ist possible to set the zero point for x/y per webcam with any software (Grbl Panel, Universal G code Sender, GRBL Commander)
    Or is there any other Software witch ist compatible with cnc xpro v2 where I can set zero point with webcam
    thx
  2. Jonny Norris
    Jonny Norris Well-Known
    yes it is possible, you need to write a macro.
    did you see my post by any chance?
    http://www.openbuilds.com/threads/camera-edge-finder.3295/
    here is the uccnc macro i wrote, maybe you can use as inspiration.
    if(!exec.GetLED(56)||!exec.GetLED(57)||!exec.GetLED(58)) // If machine was not homed then it is unsafe to move in machine coordinates, stop here...
    MessageBox.Show("The machine has not yet been homed, HOME before executing camera offset M33!");
    exec.Stop();
    return;
    AS3.Setfieldtext("",900);
    if ( (exec.GetXmachpos() == 0.000) & (exec.GetYmachpos() == 0.000) & (exec.GetZmachpos() == 0.000) ) // checks to see if machine is is still at home position
    MessageBox.Show("Theine is still at HOME position! Position camera on edge(s) and restart macro");
    exec.Stop();
    return;
    else
    AS3.Setfieldtext("The Machine is ready to do Function",900);//sets uccnc status to say ready, not a requirement.
    AS3.Setfield(12.34, 226); // x offset value (12.34)
    AS3.Validatefield(226);// applies offset value to x
    AS3.Setfield(12.34, 227); // y offset value (12.34)
    AS3.Validatefield(227);// applies offset value to y
    exec.Wait(1000);
    while(exec.IsMoving()){}
    exec.Code("G900 Y0");// moves to zero
    exec.Wait(1000);
    if(!exec.Ismacrostopped())
    MessageBox.Show("Camera offset finished!");
    else
    exec.StopWithDeccel();
    MessageBox.Show("Camera offset interrupted by user!");
    } // reports if an estop before offset and goto zero was completed
    Good Luck
  3. boskap
    boskap New
    Thx
    but I cannot start any scripts in the Software I can use
    And Mach 3 is not Supporting the cnc xpro v2 board
    Is there a way with software like the Grbl Panel, Universal G code Sender, GRBL Commander
    work UCCNC with the cnc xpro v2 ?
  4. Jonny Norris
    You can write macro scripts for grbl apparently. Sound like you need a different version of grbl
  5. boskap
    boskap New
    the board has grbl 0.9i
    but how can i start the Macro in grbl Panel or grbl commander
    they have no Buttons for macros
  6. Jonny Norris
    Can you manually enter gcode? Just type m200 if it's saved as m200.txt if it works the same way that is.
  7. boskap
    boskap New
    yes i can
    but m200 says unsupported command
    • Supported G-Codes in v0.9i
      • G38.3, G38.4, G38.5: Probing
      • G40: Cutter Radius Compensation Modes
      • G61: Path Control Modes
      • G91.1: Arc IJK Distance Modes
    • Supported G-Codes in v0.9h
      • G38.2: Probing
      • G43.1, G49: Dynamic Tool Length Offsets
    • Supported G-Codes in v0.8 (and v0.9)
      • G0, G1: Linear Motions
      • G2, G3: Arc and Helical Motions
      • G4: Dwell
      • G10 L2, G10 L20: Set Work Coordinate Offsets
      • G17, G18, G19: Plane Selection
      • G20, G21: Units
      • G28, G30: Go to Pre-Defined Position
      • G28.1, G30.1: Set Pre-Defined Position
      • G53: Move in Absolute Coordinates
      • G54, G55, G56, G57, G58, G59: Work Coordinate Systems
      • G80: Motion Mode Cancel
      • G90, G91: Distance Modes
      • G92: Coordinate Offset
      • G92.1: Clear Coordinate System Offsets
      • G93, G94: Feedrate Modes
      • M0, M2, M30: Program Pause and End
      • M3, M4, M5: Spindle Control
      • M8, M9: Coolant Control
  8. Jonny Norris
    Urm I can't really advise much here anymore I'm afraid, I have very little experience with grbl, but can you find the files that relate to the supported mcodes ? If so I expect you need to choose one you don't use and overwrite it.
    Try searching in Google "writing grbl macro" see what it comes up with.
  9. Jonny Norris
    Think this should work for a manual way of doing it.
    G10 P1 L20 X [offset] Y [offset]
    If grbl doesn't support macro then it's most likely you need a gui to do it.
    Ernest Sutherland likes this.
  10. boskap
    boskap New
    Thx for your Support
    I try it and give you feedback
  11. Jonny Norris
    No problem best of luck with it.
  12. boskap
    boskap New
    so my test
    first i Zero x and y
    i jog with the cam to the edge
    with G10 P1 L20 X [offset] Y [Offset] i can set the Offset of the cam and then
    i send G00 X0.0000 Y0.0000
    then the spindle move to the Zero
    i think that work
    i only search for a way to have a macro for this
  13. Jonny Norris
    yup thats the long and short of it
  • About Us
    [email protected]
  • Follow us on Instagram
  • Like us on Facebook
    Donate to Open Source
