Sculpfun 40W laser electrical connections
Discussion in 'Laser Cutters' started by ricklach, Dec 23, 2023.
  1. ricklach
    ricklach Well-Known
    I just received the standalone subject laser which will work out of the box. However, I want to use the laser head in my openbuild machine and while I already have a lower power sculpfun laser mounted on the machine that is 12V, the new one is 24V and requires different wiring because the laser head has two connection ports - one for the laser and one for the signal. The laser is similar to the one found on Amazon (sculpfun s30 pro max) but is a new 40W version. It has a new separate molded power connector. Are there any suggestions on how I might connect this new laser module after mounting it to my openbuilds machine. Regrettably, I do not have a wiring diagram and the company website is down for some reason - it may have gone out of business given the number of financial problems that China is faced with.
  3. ricklach
    ricklach Well-Known
    Does anyone have the GRBL settings for the new Sculpfun SF-S9 40W laser assembly?
