Run 2x nema 23 and 2x nema 17 on one board.
Discussion in 'General Electronics' started by PaulsM, Jul 23, 2020.
  1. PaulsM
    PaulsM New
    What are the options to run, for example 2 nema 23 steppers on y axis and 2 nema 17 on x and z axis. I have arduino with cnc shield and A4988 drivers for nema 17. How could I use both of the motor sizes/types? If I use cnc shield, it plugs on to arduino and nema 23 needs seperate drivers that have to be wired with arduino.. Any ideas? Thank You for Your time and stay safe.
  2. Christian James
    Christian James Journeyman
    I don't think you can because of the way the shield is populated (although I've not seen it of course). You can however make a new shield with separate feeds for the 4988's and "amped" up drivers for the Y axis but why bother? 4 appropriate drivers would be better - you may want/need to upgrade the nema 17's anyway.
    BTW, what are you building?
  3. Rick 2.0
  4. PaulsM
    PaulsM New
  5. PaulsM
    PaulsM New
    I built 50cm x 50cm 2 axis "marker" on 2x nema17, unprecise machine for learning. Now I want to go with more precise build, probably for easy milling/learning.
