Router speed controller
Discussion in 'CNC Mills/Routers' started by dddman, Apr 17, 2014.
  1. dddman
    dddman Journeyman
    #2 Rick 2.0, Apr 17, 2014
  3. Mark Carew
    I also use one and it works for me :thumbsup:
  4. GrayUK
    I thought I could use this on a Kress spindle, because although it is variable, you would have to reach across to adjust the unit on the fly. But I heard the guy say it wouldn't work with a soft start unit, which a Kress is meant to be, in the right up. Although I haven't heard what I would call a "slow start" in the You-Tube vids.
    Gray
  5. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    :D
    (Perhaps not so necessary for a small diameter router bit but ‘soft start’ is much kinder to the motors brushes / windings on higher mass cutters such as ‘disc’, ‘angle grinders’ etc.).
    Tweakie.
  6. dddman
    dddman Journeyman
    Got it for 8$ on eBay! Plus 17,66$ for shipping... Still not too bad for us harborfreight-less guys ;)
  7. Mark Carew
    @GrayUK I would not worry too much about having to change the speed adjustment on the fly, as you would normally set the speed for the material type your cutting before starting the cut.
    It is nice to have the ability to adjust on the fly for the initial 'finding' of the right speeds and feeds for the material type though.
