Router recommendation
Discussion in 'General Talk' started by Robert Drisaldi, Feb 19, 2021.
  1. Robert Drisaldi
    Using the Router11, which I am very disappointed in. Crappy collets won't release bit. (Literally have to grab expensive bits with priers and tap out with a hammer) Also, I want to add 1/2" End Mill and Ball Nose to my arsenal, but can't because of the er11 collet size limitation. So, will need to replace this brand new router...which sucks. Wanted to see if there is a particular router that anyone might recommend.,
  3. Rhett E
    Rhett E Well-Known
    User error. How are you attaching collets? If you're having to use a hammer you are doing something wrong. What machine do you have? Chances are it won't support the weight of a router/spindle that's capable of utilizing a 1/2" collet.
  4. Robert Drisaldi
    The OPenbuilds guys told me that this has been a problem with these routers and to "give it time" to loosen up, so it is not "user error". I'm using the lead 1515
    A little tightness, yes. Hammering, not normal at all.
    Collet not seated in nut prior to inserting endmill, incorrect collet (6mm vs 1/4inch) etc may rather be the issue if thats the case. ER11 is a very open and mature standard used on millions of machines. Happy to assist if you post some pictures of other details, so we can help you figure it out, or, speak to the store at http://support.openbuilds.com/support/home directly
  6. Rhett E
    Rhett E Well-Known
    I've got the same machine and Router11. My collet is very snug and I'd agree it has loosened up over time. Experts can chime in but I don't think the 1515 can support (weight) a spindle with 1/2" collet.
    Robert Drisaldi likes this.
  7. Robert Drisaldi
    Thanks Peter. I'll snap a couple of pictures and shoot them over to you. Are you aware of a mod for the lead 1515 that would enable the use for a larger router with a .50" collet?
  8. Robert-Lee
    This appears to be my problem with bit removal. Slight inward bend
  9. Peter Van Der Walt
    I'm more concerned with the extra horse power causing deflection issues. All good to have 1/2" tooling, but can the frame itself handle the cutting forces? Personally I wouldn't go there...
    Robert-Lee likes this.
    Yes that one got damaged - replace it! ER11 collets are super cheap on amazon and the usual sources because its not a proprietary standard
  11. Robert-Lee
    Ordered!
  12. Rick 2.0
    Giarc and Robert-Lee like this.
  13. Robert-Lee
    Peter -
    What would you think about using this plunge bit for larger job clearing tool
    Rhett E and Peter Van Der Walt like this.
  14. Peter Van Der Walt
    Perfect!
  15. Alex Chambers
    I use a 20mm dia 1/4" shank bit in my (Chinese clone) Makita palm router, so that bit should be fine.
  16. Giarc
    I use those. I was about to suggest them, but I see you already found them.
