Router for C Beam Machine
Discussion in 'CNC Mills/Routers' started by Ken Alexander, Oct 23, 2021.
  1. Ken Alexander
    I'm interested in ordering a C Beam machine, but you seem to be out of routers for 220/240 Volt systems. Is this temporary? Will you have more in stock soon?
    Failing that, I can buy similar routers here in Thailand, but what size of router body (the diameter) does your router mount accommodate?
    Many thanks,
    Ken Alexander
    So Phisai, Thailand
    Checkout the Dewalt 26200 from local suppliers (230v version of the Dewalt 611)
    Router mount fits 69-72mm diameter bodies
  3. Ken Alexander
    Thank you Peter!
    Ken
  4. Gary Caruso
    The dewalt is good, but the makita RT0701 is the same diameter as the RoutER11, and is cheaper than the dewalt.. But the collet is better on RoutER11 for sure.
    Gary
    Which needs the 65mm reduction sleeve, which is only sold with the RoutER11 - so he'll have to 3D print one
  6. Ken Alexander
    So is the RoutER11 not available for any voltage? Openbuilds is their only distributor according to the Gearish website. If you can't get them, then what's the situation?
    It is available, just momentarily sold out :) Contact the store for estimated arrival dates of new stock: Support shouldn't be long at all!
