Router bits for wood?
Discussion in 'CNC Mills/Routers' started by jeffmorris, Apr 23, 2018.
  1. jeffmorris
    jeffmorris Journeyman
    I have some 1/8" upcut router bits but they sometimes cause problems such as rough cuts on 1/4" plywood and can throw pieces being cut off the plywood. I tried 15mm/s feed speed. Should I get downcut or straight bits?
  2. Gary Caruso
    Are you using retention tabs? if you are and the bit is lifting the sheet then downcut is the way to go.
    Are you cutting full depth? I would go 2x faster but half depth at a time.
    can get them here
    or
    Here
